Farmall Tractors Discussion Board
Re: Re: Re: Grandpa's old tractors
Posted by big fred on July 30, 1999 at 11:18:02 from (12.13.226.16):
In Reply to: Re: Re: Grandpa's old tractors posted by Ronny Bailey on July 30, 1999 at 11:05:06:
The best thing you could find on them is the nameplate with the serial number. If you have that, the folks on this board could get you most any other info you might want.
Post a Followup
: Re: Re: Re: Re: Grandpa's old tractors
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
