Re: Hard starting IH 404
Posted by DC on February 21, 2002 at 17:18:37 from (12.93.74.110):
In Reply to: Hard starting IH 404 posted by Mark on February 21, 2002 at 13:33:01:
Mark when it is running and warmed up if you pull out the choke it should stall the engine out,if not sounds like the float is set to low or a stoped up jet hole.You can test this by taking off the air filter hose and useing your hand to choke it .Also check the timing.
Post A Followup
: Re: Re: Hard starting IH 404
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
