Re: always wondered
Posted by walt f on February 21, 2002 at 22:41:32 from (24.159.79.106):
In Reply to: always wondered posted by adam on February 21, 2002 at 21:56:27:
depends on how bad they're stuck. sometimes you can tell by just looking at the spark plugs when you remove them. if the plugs have little balls of rust on them, then that is usually an indicator that it's stuck pretty bad. even then, i've been surprised at how little damage is in the cylinders. you can loosen the rings when you remove the pistons from the cylinders. the key is patience. do not get in a hurry. make up a system to record the way you took the engine apart, so you can reassemble it later. before you take anything apart, find a way to flush out your cylinders thru the spark plug holes. i purchased a squeeze bulb like you use to add water to a battery, and put a 12 in. rubber fuel line on it. i put a half cup of gas and a tablespoon of fuel system water remover in each cylinder. i then used the squeeze bulb to suction the fuel mix into the bulb and squeeze it out again flushing the cylinder, mixing the liquid with the rust and moisture in the cylinder. i did this about ten times in each cylinder and walked away for a few minuites to do something else and came back and repeated the process over again. i did this about four times to completely saturate the the cylinder and down the sides of the cylinder, then i removed as much of the liquid as i could with the squeeze bulb. on my tractor (f-20) my sparkplug holes are big so i could stuff long thin pieces of cotton t shirt down each hole to absorb the liquid left over. i was careful not to leave any pices in the cylinder!! after a day or two i was satisfied that most of the liquid was gone i sprayed some p b blaster down each hole, and let that set for awhile. i got mine loose with the hand crank..if you need more help, just ask. someone will have some ideas.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
