Re: 1948 Super C question
Posted by Mike Little on February 22, 2002 at 03:58:03 from (167.142.12.146):
In Reply to: 1948 Super C question posted by Leslie on February 21, 2002 at 08:19:05:
I have had to put head gaskets in several of these and seen several burned valves. I am sure it was because of the unleaded gas we use now and these were made to use the leadad gas that was what made the valves live longer back then.A compression check will tell they are easy to fix.
Post A Followup
: Re: Re: 1948 Super C question
