Re: Sheet Metal Pitting
Posted by David A on February 22, 2002 at 17:09:56 from (12.155.101.39):
In Reply to: Sheet Metal Pitting posted by Farmall-Nut on February 22, 2002 at 14:54:30:
Get it rust free then apply a good automotive primer. Instead of bondo, use spotting putty for your thin coat. Comes in a tube from auto paint stores. (stuff I've used was green) Sands easier than bondo - more like thick primer. Reprime and keep sanding, reapplying and primering 'till perfect.
Post A Followup
: Re: Re: Sheet Metal Pitting
