Re: 8 Volt ??
Posted by Denny Frisk on February 23, 2002 at 08:24:03 from (216.165.146.168):
In Reply to: 8 Volt ?? posted by MikeGA on February 23, 2002 at 06:26:44:
The whole idea behind the 8V battery is to spin the engine faster (about 33% faster) than the 6V so the engine starts faster. Since You have more volts You need fewer amps. As "ADJUST" says, You can adj. the voltage reg. for higher voltage so You can charge the 8V battery with your generator. Another benefit is your lights will be brighter too!
Post A Followup
: Re: Re: 8 Volt ??
