Re: Re: sealing rings on lifter cover
Posted by big fred on February 24, 2002 at 14:49:56 from (208.51.245.80):
In Reply to: Re: sealing rings on lifter cover posted by Larry on February 24, 2002 at 08:41:38:
I used ordinary "sealing washers" from my hardware store. They are a steel washer with a rubber washer glued to them. The washer is slightly conical, the rubber washer is a tight fit on the bolt. It hasn't leaked in a couple years since I installed them. Probably about 40 cents each, don't exactly recall. Much cheaper than the copper, but not original by any means.
Post A Followup
: Re: Re: Re: sealing rings on lifter cover
