Re: Freeing the stuck M
Posted by ff316 on February 24, 2002 at 20:38:49 from (207.246.76.52):
In Reply to: Freeing the stuck M posted by Dachshund on February 23, 2002 at 18:33:37:
The PB Blaster spray works fine. Some good parts stores like NAPA can get PB Blaster in 1 gallon jugs, just ask your parts guy. I have had better luck w/ PB than WD40, Liquid Wrench, or anything else. I would probably go ahead and pull the valve cover and oil pan off, even if it unsticks easily you should check the valves and rods before starting. Good luck and post back for more info. Fireman
Post A Followup
: Re: Re: Freeing the stuck M
