Re: Grandpa's old I-544
Posted by Steven@nd on February 25, 2002 at 10:04:14 from (12.23.184.212):
In Reply to: Grandpa's old I-544 posted by Don on February 25, 2002 at 09:33:45:
I have a Farmall 544 which should be fairly similiar if you have any specific questions. Mine has 5 forward and reverse speeds. It has a shuttle instead of the Torque Amplifier. Another version of the 544 transmission was the hydro.
I believe they have a C200 4 cylinder gas engine. It is sleeveless so an overhaul requires removing the block and boring if it is too worn. The tractor is a very handy size, but the engine is very touchy on carb and point adjustments. If you do get it running and it runs erratically check the manifold, they are prone to vacuum leaks.
Steven
Post A Followup
: Re: Re: Grandpa's old I-544
