Re: Bale Cart
Posted by Haas on February 26, 2002 at 06:43:18 from (129.37.117.146):
In Reply to: Bale Cart posted by Bobby R on February 25, 2002 at 18:22:18:
Assuming the tires on the cart are 30 inch diameter and the rear axle ratio of the old truck axle is 3.73, then the 540 rpm PTO speed works out to about 13 MPH. That's a little too fast so you would need about a 3 to 1 reduction of the PTO speed to match up with say 3 rd gear on the M. I think it would work if you keep the transmission from the old truck too and connect the PTO to the front of that. Then put the old truck tranny in 1st gear and go for it.
Post A Followup
: Re: Re: Bale Cart
