need some input on getting my B cranked after 30 years
Posted by Gordon on February 26, 2002 at 14:06:26 from (65.197.75.72):
Have been trying to get my 40 model B cranked after sitting in the barn for 30 years. The engine was stuck, although not bad. A couple of shots of PB Blaster down the plug holes & it broke loose with the hand crank. I have changed the oil & filter, replaced the points, rotor, Dist. cap, coil cover cap, condenser, & put on new wires & plugs. Also had the carb. rebuilt. when she's turning over, I get a little white smoke from the exhaust. It's firing, but the spark seems awful weak to me. You can barely see the spark when a plug is grounded. Is it possible that the magneto is weak & needs rebuilt? Or am I just flat over looking something here? What should the compression be? I'm thinking maybe the rings are stuck & it doesn't have enough compression to start. I plan on rebuilding the engine, but I kinda wanted to hear it run. Any help you experts may offer will be greatly appreciated....Thanks in advance....stumped in Texas
Post A Followup
: Re: need some input on getting my B cranked after 30 years
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
