Re: BLEW that PTO
Posted by John S-B on February 26, 2002 at 14:46:22 from (152.163.207.67):
In Reply to: BLEW that PTO posted by Jon with an M on February 26, 2002 at 05:17:56:
I think the reason for there being two new seals is to keep them square on the shaft since they're thinner than the old ones. It may not seal correctly if it does'nt seat straight. Probably not critical, you might get a bit of seepage tho'. Check your bush hog also, there should be a shear pin/bolt on the drive shaft somewhere. Make sure it's not a grade 5 or 8 bolt.
Post A Followup
: Re: Re: BLEW that PTO
