Re: 18 month storage. Motor Concerns
Posted by Garidgerunner on February 26, 2002 at 17:03:07 from (205.188.192.182):
In Reply to: 18 month storage. Motor Concerns posted by Don on February 26, 2002 at 14:07:29:
I would pull the valve cover off and bump the valves with block of wood and a hammer to see if they are free and possibly avoid breaking a push rod. May do some upper end lubrication.
Post A Followup
: Re: Re: 18 month storage. Motor Concerns
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
