Re: H oil pressure
Posted by lcbateman on February 26, 2002 at 21:10:29 from (66.84.193.152):
In Reply to: H oil pressure posted by Mike ISW on February 25, 2002 at 15:57:17:
Relief Valves 101
The relief valve is simply a spring loaded plunger that allows oil to bypass once the spring pressure has been exceeded. When oil pressure builds in an engine, equal pressure is applied to all surfaces, including the oil pump cavities. If the oil pressure exceeds the pressure applied aganist the spring loaded plunger, oil is allowed to "bypass" or return to the oil pan without circulating through the engine. This design regulates the maximum oil pressure allowed to be applied to engine surfaces, journals and gaskets.
Post A Followup
: Re: Re: H oil pressure
