Re: Re: Re: Re: Giving up on Farmall M
Posted by Doc on February 26, 2002 at 22:22:36 from (204.73.55.90):
In Reply to: Re: Re: Re: Giving up on Farmall M posted by ScottyNY on February 26, 2002 at 15:05:26:
Mighty nice of you to offer your help. If he was closer to tropical Minnesota, I could help also.
A clutch disk can be installed backwards. The hub is ususally longer on one side or the other and if backwards, can cause release problems. The tractor does not need to be split if it is not a Super. The belly pump has tocome out which is the hardest part due to weight. The clutch linkage and clutch itself come out easy. Second hardest part are the bolts in the rubber hub on the drive shaft. They can be tight in their holes. I had the clutch out of my M this past summer. It was about 3 hrs., not including belly pump remove and install. That adds about an hour. Email if you have questions. Doc.
Post A Followup
: Re: Re: Re: Re: Re: Giving up on Farmall M
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
