Re: Re: Re: Re: 18 month storage. Motor Concerns
Posted by ScottyNY on February 27, 2002 at 16:11:42 from (128.59.6.14):
In Reply to: Re: Re: Re: 18 month storage. Motor Concerns posted by Don on February 27, 2002 at 14:15:32:
Lord help us, if you look in the archives you'll find more long threads than you'll ever have time to read and some pretty strong opinions on both sides of the detergent issue. You don't even want to get to brands. But the general feeling I get from it all is that detergents have been pretty much the standard for some years. For the short while I wanted to run non-det, I had to look a little to find it, but most brands sell both. Starting with a clean engine, the detergent isn't so much a scrubber as a formulation that allows small amounts of sludge to suspend itself in the oil as it develops and get it to the filter. The stuff that makes sludge with a Non-det would just settle in the pan or build up where it can because the oil wouldn't carry it away. You'll see in the threads, a few folks once had a bad experience with bearing failure or something else drastic and blame in on detergent oil and swear the stuff is poison. Can't say they're wrong--I'm not an engineer and they had the bad experience, not me. But the concept of the detergent seems sound enough. I ran non in my SuperC until I rebuilt it and nothing but detergent after. Wouldn't use a non-detergent in my car or truck. My 2c. Scotty
Post A Followup
: Re: Re: Re: Re: Re: 18 month storage. Motor Concerns
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
