Re: Farmall B steering Coupling Joint needed!
Posted by Red Raider on February 28, 2002 at 06:20:37 from (4.24.111.22):
In Reply to: Farmall B steering Coupling Joint needed! posted by Dan on February 27, 2002 at 18:17:33:
The new cross bearing available from CaseIH is not the same as the original, which may not be important to you. The original has a welded yolk unlike the press out needle bearing cap on the new.
third party image
Post A Followup
: Re: Re: Farmall B steering Coupling Joint needed!
