Re: Re: 806 Power Steering Parts
Posted by Jeff R on February 28, 2002 at 06:48:49 from (216.131.5.248):
In Reply to: Re: 806 Power Steering Parts posted by Bullfrog on February 27, 2002 at 17:28:33:
The particular part I'm referring to is the end where it bolts up to the unit on the very front of the tractor. The end of the tube is so that a hollow bolt fits through it and becomes part of the line when its bolted down and in place. Fluid flows through the line, through the bolt, and into the steering unit. There are two lines that run to that unit and both lines have the same type of end on them. The entire line would be nice to have but the ends are what I'm after. If I can get those I can flare the tubing myself and get everything up and running.
Post A Followup
: Re: Re: Re: 806 Power Steering Parts
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
