Re: Farmall 300 Brakes
Posted by Super Dave on February 28, 2002 at 08:03:56 from (206.72.20.71):
In Reply to: Farmall 300 Brakes posted by Dick Davis on February 28, 2002 at 04:14:20:
Dick, Just took the brakes apart on my 300. The outer plate after you have the brake housing and disks off is called the inner brake plate and hold the outer pinion shaft bearing. The inner plate is the pinion shaft inner bearing cage and is bolted to transmission case with 6 cap screws.
The inner brake plate has an o ring for a seal and you have to break that loose to remove the plate. Get the rust off of the pinion shaft and use a thin chisel or pry bar in the two indents between the 2 plates. As soon as you have the o ring free of the bearing cage the plate will slide right off the shaft.
Post A Followup
: Re: Re: Farmall 300 Brakes
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
