Farmall Tractors Discussion Board
Re: Re: F-12 info needed!
Posted by Farmall Gray on July 31, 1999 at 14:30:03 from (152.163.204.81):
In Reply to: Re: F-12 info needed! posted by Farmall Gray on July 29, 1999 at 19:30:43:
Here is what the parts book says on the serial #
page: "NOTE: Name plates bearing serial numbers
FS155402 to FS155902 inclusive were asigned to feild change-over packages for converting F-12
tractors into F-14."
Post a Followup
: Re: Re: Re: F-12 info needed!
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
