Re: 230 starting
Posted by ralph on March 02, 2002 at 06:08:43 from (65.45.140.89):
In Reply to: 230 starting posted by Jason on March 01, 2002 at 07:02:10:
Jason: You say the plugs seem dry. Could be your choke plate inside the carb is not choking enough when you pull on it. There is a bit learning just how much to pull the choke on some. Have someone else sit on it and start it while you stand along side and pull that choke. Gotta get gas into those plugs. Also could try covering the air intake to act as a choke. If no help, then maybe gas supply is too low to carb. Dirty carb. r.
Post A Followup
: Re: Re: 230 starting
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
