Re: Re: Re: F-12 Quick attaching hitch
Posted by Charles Norwood on March 03, 2002 at 12:11:47 from (207.178.96.211):
In Reply to: Re: Re: F-12 Quick attaching hitch posted by John *.?-!.* cub owner on March 02, 2002 at 20:37:50:
I will stand corrected. Didn't know he was talking about the drawbar, hadn't heard it called a quick hitch. Don't know about it being faster than 3 point. When I was 12, I had a hard time holding up a swinging drawbar and hooking up the bolt underneath while trying to align it with the clamps. Cultivator wasn't too bad. The bear was the semi-mounted 3 disk plow we had that used the axle clamps, two hydraulic cylinders,and pulled from a bracket underneath the tractor. Suppose you could call this a 5 point hitch, actually a 8 point if you counted all the bolts and pins, and the steering rod to the front end.
Post A Followup
: Re: Re: Re: Re: F-12 Quick attaching hitch
