Farmall Tractors Discussion Board
Re: Re: Tightening Rims On Axel??
Posted by Skip on August 01, 1999 at 03:48:49 from (204.248.83.26):
In Reply to: Re: Tightening Rims On Axel?? posted by RED Blooded on July 31, 1999 at 20:13:23:
Terry, These two post are very good advice,also the clips that hold the rim to the cast hub can get off center, be sure you check all bolts after you find the problem they will move and need retightened.
Post a Followup
: Re: Re: Re: Tightening Rims On Axel??
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
