Re: Hard time tuning converted M
Posted by Zonie on March 04, 2002 at 06:47:18 from (205.188.192.31):
In Reply to: Hard time tuning converted M posted by Robert C. on March 04, 2002 at 06:30:20:
I know there is a difference in the H's gas and distillate carbs. I have one of each for my H and I can never get the distillate carb to run right on my gasoline only H. I've tried rebuilding and cleaning many times thinking I'm missing something. I've heard many people who have distillate tractors say that they run fine on gas.
I can't help wonder if your problem isn't a vacumn leak some where. the obvious places are the gaskets between the carb and manifold.
try to spray WD-40 on these areas and see if your enginesmooths out or the engine speed changes if it does then you've just found the culprit.
Just my 2 cents worth
Zonie
Post A Followup
: Re: Re: Hard time tuning converted M
