Re: International ??? maybe
Posted by Big John on March 04, 2002 at 17:34:10 from (205.188.199.42):
In Reply to: International ??? maybe posted by Bill Ramsey on March 04, 2002 at 16:12:52:
Since the hood is missing is it possible that the grill might be from an International A. It would fit. I don't believe they ever made an International B, at least not in this country. I assume you know that a "A" has a wide front axel and a "B" has a narrow front end, and you are not confused. The serial number on an "A" will begin with the letters "FAA" and on the "B" they begin with "FAB". If by chance you do have a International "A" the serial number would begin with "IAA". You probably already know all of this. Good Luck
Post A Followup
: Re: Re: International ??? maybe
