Farmall Tractors Discussion Board
Re: Re: Turf tires
Posted by Tugboat on August 01, 1999 at 09:38:59 from (208.25.241.128):
In Reply to: Re: Turf tires posted by ltf in nc on August 01, 1999 at 07:05:20:
What I used to reduce the cleat size is a small Makita Power plane hooked up to a Shopvac vacuum cleaner. I jacked up the wheel and simply sat on a stool behind the tire. With the tractor in neutral the tire could be rotated to access a section of cleats. To hold the tire in place,just slip the transmision into gear. I did the first couple of cleats without the vacuum cleaner and messed up my shop. The shopvac had to be emptied twice but made a much cleaner job. If it works for anyone else please let me know at pgbggrenier@ncol.net
Post a Followup
: Re: Re: Re: Turf tires
