Farmall Tractors Discussion Board
Re: Question for Guy Fay re: casting codes
Posted by Don (PA) on August 01, 1999 at 10:30:29 from (205.188.199.44):
In Reply to: Question for Guy Fay re: casting codes posted by Farmaller on July 31, 1999 at 18:07:51:
Check the engine -- on the left side (you are facing forward), near the lower left corner of the side of the engine (in front of the fuel pump), there should be a flat space with a number hand-stamped onto it. Clean out the accumulated grime, and you should see your clue! This is going to be very close to your tractor serial number (it may even match, but no guarantee).
My 1935 had the numbers matching...
Good luck! Don
Post a Followup
: Re: Re: Question for Guy Fay re: casting codes
