Re: 3 pt. for super c
Posted by Haas on March 05, 2002 at 05:39:35 from (129.37.117.169):
In Reply to: 3 pt. for super c posted by maltese on March 04, 2002 at 19:57:59:
I have a C with the work saver 3 pt. I'll take a look and post again later, but I don't think and 18 inch pulley will fit on there. The back bracket that holds the top link completely blocks the belt pulley. Belt pulley will not even fit on. I suggest you look at the Saginaw hitch for the super C. Don't know if the pulley would fit either, but much better hitch. It uses a cylinder instead of the touch control, so you have to tap into the hydraulic system. Saginaw has the stuff to do that too. Click on the link for some pictures of the Saginaw hitch. Not my tractor, but posted some time ago by someone else.
Post A Followup
: Re: Re: 3 pt. for super c
