Re: Re: 1456 Oil Pressure Problem
Posted by RPM on March 05, 2002 at 11:35:25 from (63.110.182.225):
In Reply to: Re: 1456 Oil Pressure Problem posted by bduval23 on March 04, 2002 at 17:37:26:
This engine and oil pump system is very reliable, they leak at every joint but still not enough to starve engine of oil, easiest place to start is take oil pump off side of engine, take housing apart, there is a relief calve cartridge inside, perhaps its stuck or chip lodged inside, also another valve on rear lower header that supports the oil cooler right next to oil pump, maybe same fault, if nothing else find a used pump from any DT361-1206 or DT407-1256-1456-915D(early) and try it. If this dont fix it assuming guage is correct I dont know what else it could be.
Post A Followup
: Re: Re: Re: 1456 Oil Pressure Problem
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
