Re: H Hydraulic return add on
Posted by Farmer Bob on March 05, 2002 at 15:24:57 from (66.152.73.122):
In Reply to: H Hydraulic return add on posted by rhudson on March 05, 2002 at 13:52:44:
You could add on a remote hyd. unit which uses the reservour of the liftall. With the remote system you pull back and lock the regular liftall actuator rod and then use the new remote rod to both lift and lower the implement. Original lift all is only power lift and gravity fall./?FB
Post A Followup
: Re: Re: H Hydraulic return add on
