Re: Farmall M overheating
Posted by Matt in WA on March 09, 2009 at 17:41:15 from (68.116.22.177):
In Reply to: Farmall M overheating posted by Matt in WA on March 09, 2009 at 13:56:02:
Thanks guys. I actually couldn"t remember if it had a thermostat? Will check the manual, and check it out also.
No antifreeze on the dipstick,and no oil in antifreeze, power is great, so my gut feeling is that head-gasket is OK.
Old, which side of the block is the back drain plug, I only saw the front Rt one, under the radiator?
Thanks for your help.
Matt
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
