Re: '58 Farmall 560 with 600 hrs on it
Posted by Haas on March 06, 2002 at 05:36:48 from (129.37.117.197):
In Reply to: '58 Farmall 560 with 600 hrs on it posted by Darren on March 05, 2002 at 23:05:56:
A conversion kit that to use 3 pt implements to go in the fast hitch should be readily available and not too expensive. Can't believe tractor really has only 600 hrs. That's a rare find, but $6000 sounds a bit high. I'd think $4000 tops. But you never know. I saw a 450 sell at auction last fall for almost $5000. (very good condition with 2800 hrs on the meter) Also, the 560s had rear end troubles and IH had to retro fit them. You need to make sure it has the retrofit, especially if you plan any heavy work. IH marked the serial tag, I believe when the retro fits were done.
Post A Followup
: Re: Re: '58 Farmall 560 with 600 hrs on it
