Farmall Tractors Discussion Board
Re: Re: Re: Super M Farmall ???
Posted by Bob M on August 01, 1999 at 16:17:56 from (152.163.197.47):
In Reply to: Re: Re: Super M Farmall ??? posted by Dick Davis on August 01, 1999 at 05:03:45:
Dick
Yeah - 2 sets of full wheels is a tight fit, but it can be done. You gotta mount the inside set of wheels (concave or "dish" side facing out) so the hub is just clear of the axle bearing. The outer set of wheels can then be slipped on, once again concave side facing out.
Tightening the hub clamp bolts between the tires can be done with a suitable rachet, extension(s) and socket thru the spoke holes in the wheels. Not too hard to do - you just gotta be patient.
Could probably mount weights on the outside wheels, though I've never done it. Found that with 4 loaded tires on the rear there is PLENTY of weight already, without the need for wheel weights.
Somewhere I've got a photo of my Super M with the duals installed taken back in the early 70's. (The tractor is now retired and recently restored). If I can find it I'll send it along....
Bob
Post a Followup
: Re: Re: Re: Re: Super M Farmall ???
