Re: 706 t/a
Posted by Jon on March 06, 2002 at 18:56:49 from (63.168.241.176):
In Reply to: 706 t/a posted by Charles on March 06, 2002 at 18:46:04:
560 uses the mechanical TA. 706 uses the hydraulic TA. Totally different setups. On the 706 you need to split it twice(like the 560). Then pull the MCV valve and pump out. Pull out the 3 oil transfer tubes. Pull off your speed trans shifting forks, then you should be able to get the speed gears out. Take the nut off of the bottom counter shaft and drive the shaft out and remove the gears. Unbolt the TA from the front of the housing(and I believe the rear also). Then drive the TA out. I'm thinking that I'm forgetting a couple of small things, but others should be able to point them out.
Post A Followup
: Re: Re: 706 t/a
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
