Re: Super A ....smoke from breather?
Posted by David A on March 08, 2002 at 17:16:18 from (12.155.101.39):
In Reply to: Super A ....smoke from breather? posted by Marty Hundley on March 08, 2002 at 14:53:27:
Have you ever shut off a car engine while the air cleaner is off and seen a little fuel vapor rise from the carbarator? I'd say that's all you're seeing.
Post A Followup
: Re: Re: Super A ....smoke from breather?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
