Re: Formula to figure out hydraulic cylinder size???
Posted by gene b on March 10, 2002 at 09:37:13 from (63.25.167.248):
In Reply to: Formula to figure out hydraulic cylinder size??? posted by Zonie on March 09, 2002 at 22:27:01:
most important is how long a throw for the cycl and how fast do you want it to travel the larger the dia the more power but the slower it will move and what are you going to do with it might need one on each side to avoid twisting the bucket under load also what size lines are you going to run also figure out your hook up so you have enough movement
Post A Followup
: Re: Re: Formula to figure out hydraulic cylinder size???
