Re: rear wheel weights on M
Posted by Tony460 on March 10, 2002 at 16:52:49 from (64.24.84.89):
In Reply to: rear wheel weights on M posted by Dan on March 10, 2002 at 16:38:42:
150#'s each for the whole weights and 75#'s each for the halves. That is a rough figure because each weight does weigh different. Some are as much as 8 lbs. from one to the other.
Tony
Post A Followup
: Re: Re: rear wheel weights on M
