Re: 1939 M Questions
Posted by Haas on March 11, 2002 at 06:04:36 from (129.37.117.246):
In Reply to: 1939 M Questions posted by Mr. J on March 10, 2002 at 20:02:28:
If the tractor was delivered from the factory with steel wheels, 5th gear was locked out. The lockout is a 3/8 inch cap screw(bolt) located on top of the transmission. My manual does not say where, but to remove the lock out, you take out the bolt and replace it with a 3/8 x 3/4 inch long cap screw. If that is the situation, I guess you have a brand new old stock 5th gear. good luck! Checked my parts manual. It shows the lockout screw directly in front of the gearshift lever on the transmission deck.
Post A Followup
: Re: Re: 1939 M Questions
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
