Re: 1206 Shifting
Posted by the tractor vet on March 11, 2002 at 10:47:02 from (216.196.13.224):
In Reply to: 1206 Shifting posted by ihdoug on March 11, 2002 at 09:04:47:
You can fix it for not to much money , the rev shat that goes into the rev shift fork gets woren and needs replaced the top cover gets woren where the shifter goes thru and needs to be reamed out and bushed and anew shifter put in along with anew shifter cam and also replace the (as i call them the cub cadet tie rod ends ) and always make sure that the clutch and the dump valve and trans brake are kept in adjustment. and also replace all the headed pins as this will make a big inprovement. I can't tell you how many that i have fixed over the years and they will last a long time.
Post A Followup
: Re: Re: 1206 Shifting
