Re: Re: 10-20 Oil can-that came with
Posted by Will... on March 11, 2002 at 14:39:48 from (216.58.67.48):
In Reply to: Re: 10-20 Oil can-that came with posted by Bob Kerr on March 11, 2002 at 11:01:24:
Thanks Bob,I hate to keep pestering you about this linkage setup,I got it runing good but I can't get the throttle lever set right.Ok let me explain it this way: If I work the lever straight ahead of the carb by hand everything seems all right but after that any linkage I hook up doesn't seem to work right or at all.Bob because the govenor holds the linkage open is there a way to hook the levers up that compensates for this.Maybe you would have a photo of this linkage placement that I could look at.Maybe you could hit me over the head with it or something !! Will
Post A Followup
: Re: Re: Re: 10-20 Oil can-that came with
