Re: Super A and 5 foot mower
Posted by Haas on March 11, 2002 at 18:12:04 from (129.37.117.170):
In Reply to: Super A and 5 foot mower posted by Carl K on March 11, 2002 at 17:12:38:
No problem for the Super A to handle the 5 ft mower. Most conditions you will mow in 2nd gear. If you are going up a fairly steep hill, you may have to gear down. If you have hills, use caution because the Super A has a fairly high center of gravity and can be turned over. If the grass is not too high, you can mow in third, but will not get as good a job and if the lawn is not smooth be prepared to bounce around some. As the others mentioned, low hanging trees can be a problem because of the height of the Super A. I used a Super A for several years with a 5 ft woods belly mower before I upgraded to a model 140, using the same mower.
Post A Followup
: Re: Re: Super A and 5 foot mower
