Re: Waking up a WD6
Posted by Haas on March 13, 2002 at 05:21:57 from (129.37.117.213):
In Reply to: Waking up a WD6 posted by Dave on March 12, 2002 at 19:47:03:
Well, I woke up an MD that was similar two years ago. Get all the gas start stuff in good shape. I'd suggest new plugs (about $7 each!), new plug wires, etc. One of the plugs is real hard to get too, can recall which, but I had to buy a 3/8 drive deep well 7/8 socket to get to it. The 1/2 drive socket was too big to get the handle on it to turn it. Make sure the carburator is clean. Taking it off is a real chore. It's held on the manifold by 4 bolts and one of back ones is nearly impossible to get a wrench on. If you take it off, I'd suggest replacing those back bolts with socket head screws. Careful with the carb, parts are really hard to come by. Also, take off the air cleaner and check it and the tube that goes to the manifold to make sure it is open. Mine was stopped up completely with mud daubbers nests. Make sure your timing is set correctly. It's easy to get the magneto 180 degrees off time if you take the front off to replace the points. You also might want to pull the valve cover and check the clearances. You have to remove the tube between the air cleaner and the manifold to do that. Also, the gasket for the valve cover is not available from IH, I had to make my own. And, get yourself a service manual and an owners manual. If the manual for the WD-6 can't be had, then get the MD manuals, you can use them for all the diesel stuff. Once you've been through everything, get yourself a good strong 12 volt battery (these things were 12 volt from the factory) put it it in gas mode and hit the starter and hope for the best. You'll probably be surprised how easy it'll get going. Good Luck, keep us posted on progress.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
