Re: Frozen M
Posted by Jon with an m on March 13, 2002 at 05:26:31 from (158.114.92.203):
In Reply to: Frozen M posted by Indiana Boy on March 12, 2002 at 17:57:16:
I freed my stuck M by soaking the cylanders with oil and WD-40 for a week, then took the starter out and using a prybar worked the flywheel back and forth until she spun free. Be easy on the prybar, you can break a tooth off of the flywheel. After it was loose I did a compression check, it was low on #3 but after running it a while it came up and now my 41' M runs just fine.
Jon M
Post A Followup
: Re: Re: Frozen M
