Re: Re: SMTA hydraulic pump problems
Posted by Steven@nd on March 13, 2002 at 07:24:35 from (165.234.170.90):
In Reply to: Re: SMTA hydraulic pump problems posted by Tom on March 13, 2002 at 04:24:10:
The SMTA does NOT have a belly pump, SMTA's came with the live pump mounted in front of the distributor.
I'm not an authority on the SMTA pump either, but if the pump is starved of oil it will burn up. I always make sure to fill our reservoir often as we have a couple of leaks. What kind of oil are you using? I use HyTran in ours since it is used on the same implements as our other tractors with HyTran.
Steven
Post A Followup
: Re: Re: Re: SMTA hydraulic pump problems
