Re: Waking up a WD6
Posted by Bob M w/a couple more suggestions on March 13, 2002 at 08:30:59 from (165.170.128.66):
In Reply to: Waking up a WD6 posted by Dave on March 12, 2002 at 19:47:03:
Haas covered it pretty well, but let me add a couple more items:
1 - Before you install the new spark plugs shoot a couple squirts of motor oil from a hand oiler into each combustion chamber. Do this with with the decompression lever in the "gas" position. This will pre-lube the cylinder walls for the first start.
2 - Before replacing the plugs, and again with the decompression handle in "gas" position, crank the motor with the starter until oil pressure shows on the gage. This will spread the oil you shot into the cylinders, and also will insure that the crank bearings, valve mechanisms, etc. are well-oiled before you fire it the first time.
Good luck!!
Post A Followup
: Re: Re: Waking up a WD6
