Re: Waking up a WD6
Posted by Haas thought of another item on March 13, 2002 at 17:28:19 from (129.37.117.35):
In Reply to: Waking up a WD6 posted by Dave on March 12, 2002 at 19:47:03:
Change the oil in the injection pump. I guess you are aware, it has a small oil sump of of it's own. The little petcock on the side of it is the fill level. Use the same oil as in the engine. Also, you might want to get a new fuel pressure gage. When you get it going on gas, if the gage shows pressure in the run range, it's a pretty good bet it's going to run on diesel. Also, good suggestion by Bob M. I believe I actually used some penetrant to squirt in the cylinders in my case.
Post A Followup
: Re: Re: Waking up a WD6
