Re: hydrolics on a 1942 Farmall M
Posted by Zonie on March 14, 2002 at 18:25:10 from (198.81.16.169):
In Reply to: hydrolics on a 1942 Farmall M posted by redrev on March 14, 2002 at 15:16:14:
Redrev,
Did you get your clutch problem taken care of? I wish I was closer I'd have helped you out.
Your liftall uses 30 wt non detergent motor oil. Don't use regular detergent type oil as it will foam up and cause problems. You could use HyTran oil but it is much thinner than 30 wt. (About 10 wt.) and may cause lifting problems when the oil gets warmed up.
Post A Followup
: Re: Re: hydrolics on a 1942 Farmall M
