Re: Re: Cranking amps
Posted by Don Young on March 14, 2002 at 21:16:02 from (66.182.131.21):
In Reply to: Re: Cranking amps posted by Bob M on March 13, 2002 at 19:28:50:
Since for a given size case and weight the 12 volt battery will typically have half the ampere hour capacity of the 6 volt battery, it all comes out the same. It does seem that 12 volt batteries are cheaper than equivalent 6 volt batteries. Both methods have been used by manufacturers.
Post A Followup
: Re: Re: Re: Cranking amps
