Re: Cranking amps
Posted by RPM on March 15, 2002 at 06:54:05 from (63.110.182.225):
In Reply to: Cranking amps posted by Ron G on March 13, 2002 at 18:42:21:
To add in what little I can the advantage to the older systems of 2 or more 6 volt batterys hooked in series it made the reserve cranking a lot more, in other words you could run the starter longer, I think the big advantage now with 12 volt in parallel is you have the high voltage for a quick short burst and that is what you need for todays engines.
Post A Followup
: Re: Re: Cranking amps
