Re: M rear end trans oil questions.
Posted by jal-SD on March 15, 2002 at 10:02:37 from (64.68.166.199):
In Reply to: M rear end trans oil questions. posted by R Wyler on March 15, 2002 at 08:02:19:
When you drain it, you'll be suprised at the amount of water that comes out. I drain water off the bottom of my H every fall. Condensation is the main problem, I think. Do you live where its hot or cold? If its cold in the winter (-20 or so), I'd go w/80-90 to mix w/your 90. It'll shift & lube better in cold weather w/80-90 & if you don't use pull it hard for more that 12-14 hrs per day in the summer, your M won't know the difference & won't it care either, but you'll like the winter shifting. (My $0.02 worth. jal-SD)
Post A Followup
: Re: Re: M rear end trans oil questions.
